Hello!
I have two cuestions: ¿which is the correct code to display the loading progress bar in this example:?
http://www.otero27.com/daynight
¿and how I can do to make the panos load first before you can move it?
The code is from the example Slider-Blend-Cube:
loadscene(get(scene[0].name), null, MERGE);
url="hotspots/arrow.png"
altonloaded="if(isphone, mul(scale,2)); onloaded();"
ondown="startdragingslider();"
onup="stopdragingslider();"/>
set(plugin[slider_grip].backup_align, get(plugin[slider_grip].align));
set(plugin[slider_grip].backup_edge, get(plugin[slider_grip].edge));
plugin[slider_grip].changeorigin(lefttop,lefttop);
sub(mouse_x_offset, plugin[slider_grip].x, mouse.x);
sub(mouse_y_offset, plugin[slider_grip].y, mouse.y);
set(image_dragging,true);
dragslider();
set(image_dragging, false);
if(image_dragging,
add(xpos, mouse.x, mouse_x_offset);
sub(xmax, plugin[slider_bg].width, plugin[slider_grip].width);
if(xpos LT 0, set(xpos,0));
if(xpos GT xmax, copy(xpos,xmax));
copy(plugin[slider_grip].x, xpos);
div(val, xpos, xmax);
setblend(get(val));
delayedcall(0.01, dragslider() );
plugin[slider_grip].changeorigin(get(plugin[slider_grip].backup_align), get(plugin[slider_grip].backup_edge));
addhotspot(%1);
set(hotspot[%1].url, %2);
set(hotspot[%1].ath, %3);
set(hotspot[%1].atv, %4);
set(hotspot[%1].width, 1000);
set(hotspot[%1].height, 1000);
set(hotspot[%1].distorted, true);
set(hotspot[%1].enabled, false);
set(hotspot[%1].visible, false);
set(hotspot[%1].alpha, 0.0);
set(hotspot[%1].details, 16);
set(hotspot[%1].zorder, %1);
addface(face_%1_F, 'daynight/%1_f.jpg', 0, 0);
addface(face_%1_L, 'daynight/%1_l.jpg', -90, 0);
addface(face_%1_R, 'daynight/%1_r.jpg', +90, 0);
addface(face_%1_B, 'daynight/%1_b.jpg', +180, 0);
addface(face_%1_Z, 'daynight/%1_u.jpg', 0, -90);
addface(face_%1_N, 'daynight/%1_d.jpg', 0, +90);
set(%1.alpha, %2);
if(%1.alpha == 0.0, set(%1.visible,false), set(%1.visible,true));
setalpha(hotspot[face_%1_F], %2);
setalpha(hotspot[face_%1_L], %2);
setalpha(hotspot[face_%1_R], %2);
setalpha(hotspot[face_%1_B], %2);
setalpha(hotspot[face_%1_Z], %2);
setalpha(hotspot[face_%1_N], %2);
addcube(pano1);
addcube(pano2);
setblend(0);
sub(blend2, 1.0, %1);
setcubealpha(pano1, %1);
setcubealpha(pano2, get(blend2));
I hope someone can help me!
Greetings from Mexico.
