Slider-Blend-Cube Loading Bar Help!
  • Hello!
    I have two cuestions: ¿which is the correct code to display the loading progress bar in this example:?
    http://www.otero27.com/daynight
    ¿and how I can do to make the panos load first before you can move it?
    The code is from the example Slider-Blend-Cube:
    loadscene(get(scene[0].name), null, MERGE);
    url="hotspots/arrow.png"
    altonloaded="if(isphone, mul(scale,2)); onloaded();"
    ondown="startdragingslider();"
    onup="stopdragingslider();"/>
    set(plugin[slider_grip].backup_align, get(plugin[slider_grip].align));
    set(plugin[slider_grip].backup_edge, get(plugin[slider_grip].edge));
    plugin[slider_grip].changeorigin(lefttop,lefttop);
    sub(mouse_x_offset, plugin[slider_grip].x, mouse.x);
    sub(mouse_y_offset, plugin[slider_grip].y, mouse.y);
    set(image_dragging,true);
    dragslider();
    set(image_dragging, false);
    if(image_dragging,
    add(xpos, mouse.x, mouse_x_offset);
    sub(xmax, plugin[slider_bg].width, plugin[slider_grip].width);
    if(xpos LT 0, set(xpos,0));
    if(xpos GT xmax, copy(xpos,xmax));
    copy(plugin[slider_grip].x, xpos);
    div(val, xpos, xmax);
    setblend(get(val));
    delayedcall(0.01, dragslider() );
    plugin[slider_grip].changeorigin(get(plugin[slider_grip].backup_align), get(plugin[slider_grip].backup_edge));
    addhotspot(%1);
    set(hotspot[%1].url, %2);
    set(hotspot[%1].ath, %3);
    set(hotspot[%1].atv, %4);
    set(hotspot[%1].width, 1000);
    set(hotspot[%1].height, 1000);
    set(hotspot[%1].distorted, true);
    set(hotspot[%1].enabled, false);
    set(hotspot[%1].visible, false);
    set(hotspot[%1].alpha, 0.0);
    set(hotspot[%1].details, 16);
    set(hotspot[%1].zorder, %1);
    addface(face_%1_F, 'daynight/%1_f.jpg', 0, 0);
    addface(face_%1_L, 'daynight/%1_l.jpg', -90, 0);
    addface(face_%1_R, 'daynight/%1_r.jpg', +90, 0);
    addface(face_%1_B, 'daynight/%1_b.jpg', +180, 0);
    addface(face_%1_Z, 'daynight/%1_u.jpg', 0, -90);
    addface(face_%1_N, 'daynight/%1_d.jpg', 0, +90);
    set(%1.alpha, %2);
    if(%1.alpha == 0.0, set(%1.visible,false), set(%1.visible,true));
    setalpha(hotspot[face_%1_F], %2);
    setalpha(hotspot[face_%1_L], %2);
    setalpha(hotspot[face_%1_R], %2);
    setalpha(hotspot[face_%1_B], %2);
    setalpha(hotspot[face_%1_Z], %2);
    setalpha(hotspot[face_%1_N], %2);
    addcube(pano1);
    addcube(pano2);
    setblend(0);
    sub(blend2, 1.0, %1);
    setcubealpha(pano1, %1);
    setcubealpha(pano2, get(blend2));
    I hope someone can help me!
    Greetings from Mexico. *wink*
    this is a special case - the images were loaded as hotspots and the progress bar will shown only for real pano images,
    showing a loading bar or text would be possible, but a bit tricky - the "onloaded" event of each hotspot could be used to increase a user defined loading counter variable, and then this counter could be used to scale and/or mask a loading bar or to calculate a text and show that...
