Progress for loading plugins
    Is it possible to view the progress when loading/adding plugins?
    I have a plugin that is over 2MB and it would be nice to see some response when creating it.
    This is an example:
    krpano.call("addplugin(myplugin)");
    var plugin:Object = krpano.get("plugin[myplugin]");
    plugin.keep = true;
    plugin.url = "%SWFPATH%/plugins/myplugin.swf";
    plugin.handcursor = false;
    plugin.align = "lefttop";
    plugin.x = plugin.y = 0;
    plugin.visible = true;
    Would it be possible to use a Loader for this instead so that I could check the progress or is it possible to view the progress in some other way?
    /Zarillo
  • Yes, but my goal was to display some loadingbar or text describing how many percentage that has been loaded.
    I came to think of one solution for this after I published my question...
    If I would to create a plugin that loads an external swf file. Then I could use a ProgressEvent on the Loader.
    Like this:
    plugin.keep = true;
    plugin.url = "%SWFPATH%/plugins/emptyplugin.swf";
    plugin.externalurl = "%SWFPATH%/plugins/myplugin.swf";
    and then add a Loader in the registerplugin event that loads the external swf-file.
    I think that could work...
    Or are there any other solutions?
    /Zarillo
