Plugin doens't work!!!
Hi!
rootpath attribute is empty, so... what sound to play?Andrey
Thanks Andery
Of course the rootpath is not empty, but still the sound does not work...
I am confused, everything seems to be ok
This exactly how I have the plugin:
<plugin name="sound1"
url="soundinterface.swf"
alturl="soundinterface.js"
preload="true"
rootpath="sound1.mp3"
volume="1.0"
mute="false"
Root path is not the path to the sound file. Root path is the path to the root directory.
The path is wrong to the js file or the mp3 file.
Post a link and we can tell you which one is wrong. -
Hi thanks
Please can you check this file and tell what's the problem with it...
The sound start to play but the instead of the pano screen appears black...
PLEASE HELP ME
Hey Sachagrifin
you have no idea of the how I feel
Thank you
No I do. I was there too once.
Just go through ALL the examples and ALL the documentation over and over until everything starts to make sense.
Experiment and try to implement new things based on the examples and then extend into the deeper reaches of the documentation..
And of course ome back here when you get really stuck. -
I can, but first test it worked after it dind't work why?
now it's not working -
Hi yasarcan!
You can upload your xml here.
Maybe I or any profesional member can check it out in order to find the problem
Regards
Quote from [code
<krpano version="1.0.8" onstart=""startup();playsound('ambient', 'sonido/music1.mp3', loops='0')" logkey="true" >
[/code]There's a little error in this code. It has two "" before startup. It should be only one ".
Maybe this can help people in the future, it took me 20min to figure that outcheers,
=servaas=
