Hi anyone,
I am trying to get the sound working on the iPad. I read in the plugin instructions that it needed to be an "on user" event so I added an intro image that when clicked, would go away and start the sound. But it still doesn't work. Sound is fine on regular browser.
Also, I am uncertain how or if to use the "soundinterface.js" file (is this only for the latest version of Krpano (.14)? As it throws an error on the iPad - (plugin[sounderinterface] loading error: soundinterface.js)
With this specific tour I am using krpano version (.12) because it has a prebuilt template for a regular customer that I have not converted yet.
Note: When activating the sound... via removing the aforementioned image, I get a new code that says " unknown action command: playsound "
Advice/Code to get sound working on v.12
Thanks,
Tony
