Hi, Im trying to embed krpano intoo a flash project. But I'm a bit confused, perhaps someone can clear thinks up?
1) I've seen the example within the krpano package. You have to embed using the embeddedstartup method. My question, does the container have to be the stage or can it be an empty movieclip too?
2) If an empty movieclip is not possible, is it possible to specify the name or index of the krpano object?
3) What's the best way to remove it from stage, if possible. Through trial and error I managed to remove the child (basicly mass deleting everything on stage). But there were still events running that created errors.
4) Does krpano add more clips to the stage or would be deleting krpano object enough?
5) Can someone explain what exactly happens within the embbeddestartup? Krpano registers itself to stage? Add plugins to stage? Destroys existing elements? I read somewhere that adding flash plugins that use stage3d is not possible because krpano destroys the stage before it adds itself for maximum performance. Is this true?
6) Can events be binded to krpano like Event.MOUSE_LEAVE ?
