THUMBNAILS ON MAKE VTOUR (MULTI-RES) DROPLET
    look into the 'buildthumbs' action - there you see these lines:
    set(plugin[get(thumbname)].width,  40);
    set(plugin[get(thumbname)].height, 40);
    mul(plugin[get(thumbname)].x, i,3);
    mul(plugin[get(thumbname)].y, i,3);
    add(plugin[get(thumbname)].x, 5);
    add(plugin[get(thumbname)].y, 5);
    these lines are setting the startup size and position of the thumbs:
    i = the index of the thumb (0-n)
    the position will be calculated that way (by default):
    x = i*3 + 5
    y = i*3 + 5
    change that maybe to:
    x = 5
    y = i*45 + 5
    as code:
    set(plugin[get(thumbname)].x, 5);
    mul(plugin[get(thumbname)].y, i, 45);
    then all thumbs will be aligned in a column form,
    and finally change the onclick event of the thumbs to directly load the scene instead of changing the thumb positions,
    change that line:
    set(plugin[get(thumbname)].onclick, openthumbs() );
    to
    set(plugin[get(thumbname)].onclick, loadscene(get(linkedscene),null,MERGE,BLEND(1)); );
