1.8.0.15 tools much slower?
    Just downloaded the last tools release and it appears all tools are very much slower than the previous version.
    Running on OSX Lion.
    if i run previous version again it still run fast.
    any idea?
    hmm... there were no changes that could explain a 'much slower' working...
    Can you please describe your test scenario?
    - 32 or 64bit version?
    - size of the input image?
    - installed Ram?
    - free Ram when starting the tool?
    Note - the krpano tools are only using the currently free available ram and when not enough
    ram is available then they will start swapping memory to disk - and this is extremely slow, compared to normal working.
    Maybe in your test this was the reason for the performance difference...?
  • tif file is 220mb
    64 bit version
    10gb ram installed
    i drag the tif file over makevtour droplet first in 1.8.0.15 folder, takes 6,20 min to process the file.
    20 seconds for the 1.8.0.14 version tested just after
  • What image type? (sphere, cubical, flat) and what pixel dimension? (or fov) does the image have?
    Maybe it's the sphere/cylinder to cube conversion which makes the difference...?
    The default limit settings when converting a sphere to a cube were reduced in the 1.0.8.15 version (from 360x120 to 360x45).
