Hello
I've got a problem running krpano on Debian 64bit. With kmakemultires to be exact. Does krpano work on Debian? Maybe it needs some kind of new libraries? When I run kmakemultires on Debian it turns back „Segmentation fault” error. What can that mean?
When I call to exec() and system() in php it gives 139 result and nothing happens. Earlier I had a try to run kmakemultires on Ubuntu 64bit and it worked. I've used command ./kmakemultires –config=templates/normal.config ./1.jpg. The same directory with files don't work on Debian.
