Dear Krpano community,
I have some problem with two png plugins. I'm applying some crop to them to show different states for the buttons, but the problem is, that when I load another panorama, they get distorted.
Now it's wierd because I know it's the crop - if I remove all cropping code, this doesn't happen.
However at the same time I double checked crop values and they seem to be fine, and also, if this was a crop problem, wouldn the image get cropped (maybe badly) instead of becoming distorted?
Check this image to see what the actual problem is:
As you can see it looks much more like scaling then cropping, but there is no scaling code working in the background...and again, if I remove cropping code, it doesn't happen. What could be the solution? Is this a bug, or am I just overlooking something?
Thanks for any help in advance!
