Hi
I do not know if it is only me or the look of the hotspots on HTML5 is way bigger than flash ... i am using the latest versions of players & scripts
is there a way to control this?
Thanks,
Rares
Hi
Thanks,
Rares
Try scaling differently on device bases: E.g.:
<plugin name="grb_osijek" url="%SWFPATH%/images/grb_osijek.png" align="lefttop" keep="true" alpha="1" scale="1" handcursor="false" visible="false" x="10" y="10" zorder="9" onhover="" onclick=""/><krpano devices="mobile"><plugin name="grb_osijek" scale="0.5"/></krpano><krpano devices="html5"><plugin name="grb_osijek" scale="0.7"/></krpano>
See devices here: link
thanks for you advice :)
i thought there is a hotspot property that controls this without duplicating the hotspot ... there are tours where i have 100 hotspots ... i wouldn't want to make 2-300 :)
Rares
It is duplication of hotspots. It is redefinition of scale property based on device type.
Even so, this can be significant code behind.
Think about usage of onloaded attribute.
E.g. define your hotspot style and put something like this there:
I would say there must be something wrong in the xml itself, because normally all sizes should be the same in Flash and HTML5...
I can see the chance people think their hotspots/plugins are to big on e.g. Ipad. As they have huge native desktop resolutions where all work is prepared and than when testing on real devices which have lower resolutions it might be the case of relative size looks bigger. This happens to me when both new monitor with huge resolution
For such situation using a <style> with different devices settings might be the easiest solutions,
e.g.
<style name="hotspotstyle" .... scale="1.0" devices="desktop" />
<style name="hotspotstyle" .... scale="0.5" devices="tablet" />
<style name="hotspotstyle" .... scale="0.5" devices="mobile" />
and:
<hotspot name="spot1" ... style="hotspotstyle" ... />
<hotspot name="spot2" ... style="hotspotstyle" ... />
<hotspot name="spot3" ... style="hotspotstyle" ... />
Hi guys,
Thanks for all your input ... i think that klaus is right about using dedicated styles for each device
maybe it is important to say that this change appeared when i upgraded the viewer to 1.16.4
this is the tour => http://www.360tourist.net/view-tour/3132
this is the xml => http://www.360tourist.net/read-tour/3132
i honestly do not understand how can this be an xml issue :(
thanks,
Rares
Zitati honestly do not understand how can this be an xml issue :(
But it's one
The link to the pano doesn't work, but the xml one and there I found this hotspot xml code:
See here:
https://krpano.com/docu/xml/#hotspot.scale
https://krpano.com/docu/xml/?version=10814#hotspot.altscale
With 'altscale' an 'alternative scaling' for HTML5 will be defined and this overrules the normal scale setting, so in HTML5 the scaling is 1.0 and on Flash its 0.3.
Awesome :)
see ... we learned something today :P
Thanks,
Klaus :)
