Long time no post!
Check out this couple of weeks ago house i shot virtually. What you think about the picture quality and useability of the tour?
http://www.passojadesign.com/wp-content/upl…ie/kierros.html
Regards,
Long time no post!
Regards,
Nice tour! What I'd suggest to improve (and this minor discomfort is quite often seen on many tours, especially those made with "make tour" droplet): if a hotspot is somewhere in the lower part of the pano, the "looktohotspot" action makes the virtual visitor "bang his/her head against the floor" every time they make transitions. Better would be to use "lookto" action with hotspot's ath as destination, then the movement will always be horizontally levelled. ![]()
Hi Alexey!
Thanks for the feedback! Appreciated much :)
Which hotspots in the tour were too low for you to make you hit head on the floor? Some spots i place so that they don't cover any critical places in the tour what people would like to see since this house is for sell. And i had to finish it pretty quick, in couple of hours. But i will look into this! It's not a big deal to change it :)
Regards,
Hi!
E.g., in the first very scene, there's a transition called "Olohuone" which makes you zoom so fast and right against the railing corner.
Try updating my hotspot onclick code for your needs, if you wish. Here it is:
onclick="lookto(get(hotspot[get(name)].ath),0,50,tween(easeInSine,2),true,false);wait(0.1);if(device.flash, loadscene(get(linkedscene),null,MERGE,ZOOMBLEND(2,3)); , loadscene(get(linkedscene),null,MERGE,BLEND(2)););"
Thank you :) I will definitely look into this late. Other solution is simply to just limit the zooming at onclick so it will just turn to the hotspot. Need a bit of time to figure out what works the best :)
Cheers!
Thanks for sharing Alexey, I tried it and not only leveled but also smoother transition.
