Posts by hub
zorder of hotspots doesn’t work. Look at the picture:
I work on macOS v.10.13.2 with KRPano version 1.19-pr14
Kind regards,
Hubert
Good evening Klauss,
I thought I could make a responsible, « mobile » variant of my web site which works thanks to the KRPano (http://www.annecypanoramique.com). On iPhone, a part of screen always remains reserved for its menu. According to the model, and the orientation, it is allways a different part of the screen. Locking the orientation in « portrait » mode for all "mobile" devices would make the design possible.
Hubert -
I wish to keep the display on the screen of smartphone in vertical position independently of the position of the device. How can I make it?
Hubert -
I have just updated my KRPano by downloading the 1.19-pr7 version.
Can you tell me why the MAKE VTOUR ( MULTIRES) droplet produces the VT that is made with the last equirectangular only and overwrite all other panos.
It happens with TIF equirectangulars (originals); with JPG everythink is OK.
Hubert -
OK! Thanks for your answer.
hub -
I have exactly the same problem.
Hub -
Thank you Sacha,
The solution that you propose works fine.
Hub -
I would like to have a command in the parameters of the VIEW who would allow an adjustment of the North between panos; so that all the panos of the virtual tour were directed in the same direction; so that we can apply the KEEPVIEW command and look in the same direction when passing between panos.
It is not enough to begin to take the first shoot of the pano, in the direction of the North. Because of the numerous installations, inside the buildings, the North often goes astray. The configuration of the panoramic head with regard to the North is not precise. An adjustment by means of the script, during the editing would facilitate the task. A kind of " header ", as for the radar, but applicable to the pano orientation inside the virtual tour.
HubHere you are an exemple to show for what kind of presentation may it be used: http://www.annecypanoramique.com/EXEMPLES/PAN-GATO/
Try to keep the horizontal lines parallel to the screen, then, click the next hotspot and go ahead. I would like to find all horizontal lines of the new centering in the next pano in the same parallel position. -
No bug - good news! Thank you for this explanation.
Hub -
May you tell me please, if I found a bug in the newest (1.17.4) textfield plugin? Perhaps it is now necessary to use a different coding?
I wish to have the same white color of the link as the rest of my text, but the color attribute of hyperlink is not correctly interpreted.
<plugin name="info09pano01"
url="../plugins/textfield.swf"
devices="desktop|tablet"
children="true"
align="lefttop" x="50" y="60" width="500" height="50"
zorder="2"
html='Thank you for your visit! Enjoy your tour ! [a href="event:action(hide-info09pano01);openurl(http://facebook,_blank);" style="color:#FFFFFF;"]Let us know, if you like it ![/a]'
css="text-align:left; color:#FFFFFF; font-family:Arial; font-size:14px;"
autoheight="true"
vcenter="false"
background="true"
backgroundcolor="0x000000"
backgroundalpha="1"
border="true"
bordercolor="0x000000"
borderalpha="1"
borderwidth="20.0"
roundedge="0"
keep="false"
visible="true"
handcursor="false"
I meet the same problem as the last time (simple (please) code to send an e-mail) and I do not manage to solve it now.
I put an e-mail button as a plugin in my panorama.
My client ask me to add a text prepared to be send as the massage by e-mail:
« Sur le blog de la liste Unis pour Cruseilles, on trouve deux photo-panoramas en 360°. C'est bluffant, on a l'impression d'être présent à cette réunion. A voir à tout prix et à diffuser sans modération http://cruseilles2014.blogspot.fr/p/reunions-documents.html »
The problem is that:
- French caracters are not recognized.
- The length of the text is very limited, otherwise, it does not appear.
- The hypertext (URL) is not active.Here is the code:
<plugin name="email_button"
url="img/email.png"
keep="true"
zorder="7"
align="righttop"
x="30"
y="100"
onclick="openurl(mailto: ?subject=Le panorama est bluffant - on a l impression d etre present a cette reunion avec l equipe UNIS POUR CRUSEILLES &body=a voir- http://cruseilles2014.blogspot.fr/p/reunions-documents.html,_self);"
/>And here is the link towards the pano:
http://www.annecypanoramique.com/UNIS-POUR-CRUSEILLES/I would be very satisfied if you helped me.
Best regards, Hub
After changing the quote characters, it works fine.
Thank you very much,Best regards,
Hub -
I have Adobe Flash security autorisation for some folders where I put my current work. It is not a problem. Everything works fine and I can test separately the same code with Flash or with HTML5.
If I complete the plugin textfield with global onclick="openurl(http://.....,_self); it works very well.
The only problem is that I can not open with iPad (HTML5) another website by clicking one selected word (or a groupe of words) in the text body of the textfield. It must be possible, because I have show me your example. -
I did it without success.
How it is possible that it works in your VT?
Thank you that you tried to help me.
Hub -
Fatal error
I thought it was a type writing error in your code...
If I copy and paste,
I get black screen with a notice: "FATAL: pano01.xml -XML parser error, element is malformed (dieze 1090)
the same with the brackets [].... -
Quote
Is the pano linked from wordpress site or similar?
I introduced manually the URL in Safari browser (I use Mac) to verify if it works, then I copied it from the URL window of the browser and paste into my message on the forum.
That's XLM file:
Display More<krpano version="1.17"> <view hlookat="0" vlookat="0" maxpixelzoom="1.0" fovmax="150" limitview="auto" /> <preview url="pano01.tiles/preview.jpg" /> <image type="CUBE" multires="true" tilesize="512" progressive="false"> <level tiledimagewidth="3183" tiledimageheight="3183"> <cube url="pano01.tiles/mres_%s/l3/%v/l3_%s_%v_%h.jpg" /> </level> <level tiledimagewidth="1536" tiledimageheight="1536"> <cube url="pano01.tiles/mres_%s/l2/%v/l2_%s_%v_%h.jpg" /> </level> <level tiledimagewidth="768" tiledimageheight="768"> <cube url="pano01.tiles/mres_%s/l1/%v/l1_%s_%v_%h.jpg" /> </level> <mobile> <cube url="pano01.tiles/mobile_%s.jpg" /> </mobile> </image> <hotspot name="hs-info09pano01" url="images/hs-info.png" devices="all" keep="false" ath="78.7" atv="3.9" zoom="false" scale="0.6" visible="true" zorder="2" alpha="1" smoothing="true" onover="tween(scale,0.8,0.3);" onout="tween(scale,0.6,0.3);" onclick="action(show-info09pano01);" /> <hotspot name="hs-info09pano01bis" url="images/hs-info-bis.png" devices="all" keep="false" ath="78.7" atv="3.9" zoom="false" scale="0.6" visible="false" zorder="2" alpha="1" smoothing="true" onover="tween(scale,0.8,0.3);" onout="tween(scale,0.6,0.3);" onclick="action(hide-info09pano01);" /> <plugin name="info09pano01" url="plugins/textfield.swf" devices="all" children="true" align="lefttop" x="50" y="50" width="500" height="50" zorder="2" html="Thank you for your visit! Enjoy your tour ! [a href='event:openurl(http://www.annecypanoramique.com,_blank);' style='color:#FFFFFF;'][u]Let us know, if you like it ![/u][/a];" css="text-align:left; color:#FFFFFF; font-family:Arial; font-size:14px;" autoheight="true" vcenter="false" background="true" backgroundcolor="0x000000" backgroundalpha="1" border="true" bordercolor="0x000000" borderalpha="1" borderwidth="20.0" roundedge="0" keep="false" visible="false" handcursor="false" /> <plugin name="off-info09pano01" url="plugins/textfield.swf" devices="all" parent="info09pano01" align="righttop" edge="center" x="-10" y="-5" width="20" height="20" zorder="4" html="X" css="text-align:left; color:#FFFFFF; font-family:Arial; font-size:14px;" vcenter="false" background="true" backgroundcolor="0xFFFFFF" backgroundalpha="0" border="true" bordercolor="0xFFFFFF" borderalpha="0" borderwidth="20.0" keep="false" visible="true" onclick="action(hide-info09pano01);" /> <action name="show-info09pano01"> set(plugin[info09pano01].visible,true); set(plugin[off-info09pano01].visible,true); set(hotspot[hs-info09pano01bis].visible,true); set(hotspot[hs-info09pano01].visible,false); </action> <action name="hide-info09pano01"> set(plugin[info09pano01].visible,false); set(hotspot[hs-info09pano01bis].visible,false); set(hotspot[hs-info09pano01].visible,true); </action> </krpano> -
Strange behavior.
I can open this link if I put it directly into my Safari browser. The pano is visible but the hyperlink into the textfield doesn't work.
I can not open the panorama if I click into the same link put on the forum.Try this link: http://www.annecypanoramique.com/TEMP/pano01-html5-auto/
in HTML file I set html5="auto"Hub
