Hello everyone, I'm having a little and annoying problem, when I load the bingmaps plugin the spot of the current scene doesn't appear on top of the rest, It appears with the active layer (different color) but not on top. Clicking on any other spot afterwards brings them to the top, so they work fine. The problem is when loading, any ideas on how to fix this?
Active spot in bingmaps doesn't appear in front at first
Flash or HTML5?
If HTML5 - which browser?
Do you have an example?The z/deep-order itself is normally managed automatically by the Bing Maps API - normal spots have set zIndex=1 and the active spot has set zIndex=2 - and in my tests this is working correctly...
Hello, Klaus, thanks for the quick answer, I ran a few more tests and located the problem to be only in Flash, in HTML5 everything works great, as soon as I go into Flash the activespot goes behind the other non-active spots. Tested in both Chrome and Firefox, krpano 1.17 and plugins also.
You said that "normally" the zorder of the mapspots is generated by Bingmaps API, is there a way for us to specify it?
Thanks!
do you have an example for testing?
For me the spot order works correctly in the Flash bingmaps plugin (just tested).Best regards,
