Hello
I want to convert cylindrical panoramas to cube : it's one single jpg file, but not equirectangular.
Result whith standard cube2equi command is distorted at top and bottom particurlarly, due to the input format.
Is it possible to indicate the fov while converting so the resulting cube isn't distorted or should i modify my input image thru php by adding blank areas to complete the equirectangular source ?
Thanks for advise!
