autorotate command to left in actionscript...
  • hye Klaus... wht is the code/command for calling autorotate to left other than this..
    var calls:String = "";
    calls += "autorotate.enabled,true;";
    calls += "autorotate.accel,-5;";
    calls += "autorotate.speed,-10;";
    krpano.call(calls);
    maybe im wrong.... but this code didnt work..
  • var calls:String = "";
    krpano.call(calls);
    the set() is missing
    correct would be:
    calls += "set(autorotate.enabled,true);";
    calls += "set(autorotate.accel,-5);";
    calls += "set(autorotate.speed,-10);";
    krpano.call(calls);
    or better: (without call, just set direct)
    krpano.set("autorotate.enabled",true);
    krpano.set("autorotate.accel",-5);
    krpano.set("autorotate.speed",-10);
    or even better: (from the code performance aspect)
    var autorotate:Object = krpano.get("autorotate");
    autorotate.enabled=true;
    autorotate.accel=-5;
    autorotate.speed=-10;
