I managed to find a little issue when entering in VR mode with my phone (HTC 10 ) . For some odd reason when I enter the VR mode the vr cursor is not working. I've looked more into it and found that the webvr_onentervr action checks if the device screensize is unkown and enters the vr_setup(); action. When it does so the first thing it does is set the webvr.vr_cursor_enabled to false. However the vr_setup(); action is not displayed therefore my device's vr_cursor_enabled remains disabled and can't be used to click on hotspots.
What i did to overcome this is to add in the webvr_onenetervr action a vr_setup_close() and vr_setup_save(). which enables back the vr_cursor_enabled setting.
Is this a correct method and are the save and close actions something that should be considered within the weber_onentervr action.
Thanks for your reply ;)
-Alaa
