BING and GOOGLEMAP Has Big BUG using over 200 spots.
  • Dear Klaus,
    We made a project and we take more than 2000 photos and use photos 2000 spots in googlemaps and bingmaps.
    Google maps plugin problems:
    1. Bing maps it is working but in Google spots if over 1000 or 2000, it start to not work krpano or makes so so slow down.
    2. And over 200 spots in googlemap onover working with a latency.
    There is a Bing maps problem too:
    1. <layer name="maps" .... zoom="17" onmapzoomed=" get(layer[map].zoom)" > İf you change the zoom level it gives always “17” with this get(layer[map].zoom)
    2. In bingmaps if we didnt write “active=true” to only one spot it will not show all spots.
    Suggestion for Google maps and bing maps can you add visible true and visible false for spots?
    I’m sending the sample of bing and googlemaps plugins, you can see the problem. Can you check please.
    Thank you for your helpings.
    Sample file is in here https://yadi.sk/d/MxG28sH4zxd6EQ
    Ulas AKSAN
    Aksan Bross
    PanoramicWEB Solutions.
