Deeplinking & default view settings in scene
  • Deeplinking wont unfortunately work if there is a default view in the
    tour.xml scene (hlookat="40.0" vlookat="40.0" fov="100") is set.
    I guess there is a change in tour.xml and/or in the skin.xml is necessary,
    to overwrite the default view on startup, if there
    is a startactions=lookat(24.63,2.9,90,0,0) in the URL is detected.
    I tried yesterday the whole day w.o. success - any ideas? *smile*
    Thx..
  • Hi)
    If you pass variables to Krpano via deeplinking, like
    ?view.vlookat=90
    then this variable gets overwritten during the 'loadscene' call when the 'vlookat' from the loaded scene is parsed and set.
    Switch on the 'deeplinking' parameter inside the 'skin_settings' and then you have the needed parameters inside URL to select needed scene and start view settings.
  • Thx for your reply Alex.
    I am afraid, that I did not asked precise: i want to use both features - together.
    Deeplinking is working. DEfault view is working too. But not together.
    a)if the page is called without startactions/vlookat, the default view should be taken
    b)if there vlookat in the URL, this one should taken.
