Has anyone else had an issue viewing panos in VR with a oculus rift s when running the latest firefox version 70.0?
The error is a partial tile load with everything else remaining black and a infinite spinning cursor. All is fine with firefox 69.03.
Just curious if you are using v1.20 to test. If not, see if that makes a difference. It does on the Go.
Yes using, 1.20.2 and the same issue exists on 1.20.1. I can also replicate the problem on two seperate machines with different headsets. At the moment we are usuing an old version of firefox but it continually suggests to update. The issue seems to be firefox / KRPano related as momento360 files work fine with VR. This issue exists for me on files created via KRPan and all KRPano examples on the site.
Having the same issue with 1.20.1 on Firefox 70.0.1 and Oculus Rift. However it was working initially though not sure if Firefox updated and broke it.
Hi, is there any knowledge of a fix for this? There is still the same issue on update to latest krpano 1.20.6 and Firefox 75.0.
Using Oculus Rift with latest version 16.0.0.118.452.
Thanks.
