Hi all,
I was looking for a way to create an image loop based on the washing machine example:
[https://krpano.com/krpano.html?xm…chmaschinen.xml ]
I succeeded at last, but only by creating a "restart"-action which has an empty tween method...
If I leave that out, the framenumber has no reset.
There has to be a better method for this,
but at the moment I can't werap my head aroiund this...
Also, the update_frame call in the tween method is called far to often.
Any help is appreciated -
I will build an awesome demo example with this!
Here is my code
<style
name="spotstyle"
distorted ="true"
enabled ="false"
alpha ="0.0"
zorder = "2"
onloaded="calc_pos_from_hfov_yaw_pitch_roll(159, -2.8, 29.6, -0.0);"
<action name="animate">
// showlog(); trace(' active');
txtadd(distanceparameter, 'distance(', get(hotspot[%1].maxframes), ',', get(hotspot[%1].frametime), ')');
if(hotspot[%1].state == 'stop',
set(hotspot[%1].state, 'start');
tween(hotspot[%1].startframe, get(hotspot[%1].maxframes), get(distanceparameter), linear, restart(%1), update_frame(%1) );
// set(hotspot[%1].state, 'stop');
// tween(hotspot[%1].startframe, 1, get(distanceparameter), linear, restart(%1), update_frame(%1) );
<action name="restart">
trace('restart');
// trace(%1);
//txtadd(lastframe, get(hotspot[%1].framename), get(hotspot[%1].maxframes) );
//set(hotspot[get(lastframe)].alpha,0.0);
tween(hotspot[%1].startframe, 1, 0, linear, null, null );
delayedcall(0, animate( %1 ) );
<action name="update_frame">
copy(framenumber, hotspot[%1].startframe);
Math.floor(framenumber);
// trace('framenumber ',framenumber,' active');
for( set(i,1), i LE hotspot[%1].maxframes, inc(i),
txtadd(thisframe, get(hotspot[%1].framename), get(i) );
if(i == framenumber,
set(hotspot[get(thisframe)].alpha,1.0)
set(hotspot[get(thisframe)].alpha,0.0)
<!-- based on hugin stitching: https://krpano.com/forum/wbb/index.php?page=Thread&postID=38120#post38120 -->
<!-- these are the frames -->
<hotspot name="pool1" style="spotstyle" url="scene01/spot01/frame-01.jpg" />
<hotspot name="pool2" style="spotstyle" url="scene01/spot01/frame-02.jpg" />
<hotspot name="pool3" style="spotstyle" url="scene01/spot01/frame-03.jpg" />
<hotspot name="pool4" style="spotstyle" url="scene01/spot01/frame-04.jpg" />
<hotspot name="pool5" style="spotstyle" url="scene01/spot01/frame-05.jpg" />
<hotspot name="pool6" style="spotstyle" url="scene01/spot01/frame-06.jpg" />
<hotspot name="pool7" style="spotstyle" url="scene01/spot01/frame-07.jpg" />
<hotspot name="pool8" style="spotstyle" url="scene01/spot01/frame-08.jpg" />
<hotspot name="pool9" style="spotstyle" url="scene01/spot01/frame-09.jpg" />
<hotspot name="pool10" style="spotstyle" url="scene01/spot01/frame-10.jpg" />
<hotspot name="pool11" style="spotstyle" url="scene01/spot01/frame-11.jpg" />
<hotspot name="pool12" style="spotstyle" url="scene01/spot01/frame-12.jpg" />
<hotspot name="pool13" style="spotstyle" url="scene01/spot01/frame-13.jpg" />
<hotspot name="pool14" style="spotstyle" url="scene01/spot01/frame-14.jpg" />
<hotspot name="pool15" style="spotstyle" url="scene01/spot01/frame-15.jpg" />
<hotspot name="pool16" style="spotstyle" url="scene01/spot01/frame-16.jpg" />
<hotspot name="pool17" style="spotstyle" url="scene01/spot01/frame-17.jpg" />
<hotspot name="pool18" style="spotstyle" url="scene01/spot01/frame-18.jpg" />
<hotspot name="pool19" style="spotstyle" url="scene01/spot01/frame-19.jpg" />
<hotspot name="pool20" style="spotstyle" url="scene01/spot01/frame-20.jpg" />
<hotspot name="pool21" style="spotstyle" url="scene01/spot01/frame-21.jpg" />
<hotspot name="pool22" style="spotstyle" url="scene01/spot01/frame-22.jpg" />
<hotspot name="pool23" style="spotstyle" url="scene01/spot01/frame-23.jpg" />
<hotspot name="pool24" style="spotstyle" url="scene01/spot01/frame-24.jpg" />
<hotspot name="pool25" style="spotstyle" url="scene01/spot01/frame-25.jpg" />
<!-- this is the animated hotspot -->
<hotspot name ="pool_animated"
url ="scene01/spot01/frame-02.jpg"
distorted ="true"
enabled ="false"
zorder = "0"
alpha ="1.0"
startframe ="1"
maxframes ="50"
frametime ="4"
framename ="pool"
state ="stop"
onloaded ="calc_pos_from_hfov_yaw_pitch_roll(159, -2.8, 29.6, -0.0); animate(get(name));"
Thank you in advance and best regards,
MT
