How to make input from textfield-plugin to map-plugin and add spot on map ?
  • Hi everyone.
    I am new in krpano, I am trying to add textfeild on pano to be one input box the idea is to pass the values that enterd by user to my map-plugin in xml file in order to add spot on map. So, the input format is about coordinates latitude and longitude.
    I found out on krpano forum this link: https://krpano.com/forum/wbb/inde…ad&postID=52434 its working but when i still cannot deal with inputted value.
    in my xmle file:
    addplugin(input);
    set(plugin[input].url, %BASEDIR%/textinput.js);
    set(plugin[input].align, rightbottom);
    set(plugin[input].x, 180);
    set(plugin[input].y, 20);
    set(plugin[input].width, 150);
    set(plugin[input].height, 30);
    set(plugin[input].onchanged, plugin[map].addstylespot(get(spot_pin_google)), get(text)[1], get(text)[2], 0, get(coordinate_spotstyle)));
    Here in red colored parameters i wanted to be the entered values but should splitted to two values at first then pass it spot-map.
    Any idea on how split the enterd value to two values and pass it spot as lat and lng ??
    Thanks in advance gurus,
