The previous version did not remind us of this issue, do we need to set it up there? I am currently using 1.22.2
Android phone crashes while running
- Offizieller Beitrag
What was the previous version?
Which Android devices?
Link to your example? -
Looking at the document, I think I used custom encryption and the plugin didn't load? I am trying, thank you for your support
The detailed information has been sent to the email mail@krpano.com I am eagerly waiting for the upgrade of the system and looking forward to guidance.
The reason has been identified. For Android phones, type="krpano" takes up a lot of resources. Can it be optimized
The 'resource needs' between the krpano versions should be the nearly the same, especially related to WebGL resources. So that might be not the reason for your problem...
Also note: depending the browser the number of WebGL contexts can be limited, especially on mobile devices, e.g. to just 2 contexts. In such case, when creating a new one, the old one loses its rendering context (and that message appears).
Depending what you need or do, you could try using only CSS3D rendering (without WebGL).
E.g. to create a krpano layer without WebGL:
More information here:
krpano.com - Documentation - Embedding into HTML -
Thank you for your support. Let's try again
