XML parser error : element is malformed (n°1090).
OK, problem solved... And I think it may interest you, Klaus !
As I have encrypted my xml all together, some of them were corrupted...Have you heard about this problem ?
Regards,
David
sorry, no, I don't know about that problem...
have you used the latest beta 9 krpano.swf?
or where did you have the problem? online?
if yes - maybe your ftp tool had tried a ascii to binary conversion on uploading,
and corrupted the files in that way...best regards,
No, no, it's offline, with the latest version, and only for some of the xml encrypted in the same time (around 12 xml in the same time)...
I had to test them one by one to re-encrypt the corrupted ones before upload... -
hmm, okay, thanks!
I will try to find something,best regards,
and corrupted the files in that way...personally, i have the same problem but only online... so i will check my ftp tool...
hi guys
i have the same problem it keeps on tellinh krpano.swf loading error
cheers
Rahim
i found it all you have to do is to go to setup then choosethe krpano.swf file that is in the krpanotools folder and then it will work fine
cheers
Switching my ftp transfer type from ACCII to Binary solve my problem.
Thanks Klaus
