There are a few problems when you try to use a flex application as a plugin with krpano. I'm learning flex myself, but after about a week of searching and testing I managed to work out a few of the problems; enough so I could use mxml. Most problems come from the fact that we have to use an application container which holds all our controls.
I wanted to share in case there are others out there trying to use flex application with krpano. Please feel free to add any comments.
If something is wrong or you know an easier or better way to solve a particular problem please let me know so I can edit this post. If you have solutions to other problems, please share.
I'm using Flex Builder 3, with Flex 3.5.0.12683 sdk.
PROBLEM: Any controls placed in the application container are being scaled (changes size) when you resize the window. This applies when you are using using width or height percentage values for <plugin>. For example <plugin width="100%" height="100%">
If you use a fixed size for width and height, you will not have this problem, but then all your controls will not be aligned when there is a window resize. <plugin> allows for aligning controls but this aligns the entire plugin. In a flex application you can have many controls aligned in many different ways.)
SOLUTION: Do not set width and height value for <plugin>. Simply do not use it. This tells krpano to use the application width and size. In your application mxml set your width and height to any FIXED value. (No percentage).
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" backgroundAlpha="0" width="500" height="500">
Then we need to tell our container to resize itself everytime the stage resizes. Add an eventlistener:
And a handler that resizes the application container:
private function onStageResize(evt:Event):void
if(stage.stageWidth != width || stage.stageHeight != height)
width = stage.stageWidth;
height = stage.stageHeight;
PROBLEM: The controls are not the same size as when I created them. For example, a perfectly square button is shown like a rectangle in krpano.
SOLUTION: Application container has a different value than what you set in <plugin> width and height. Either make sure they have the exact same size, or simple do not use it width and height values for <plugin>
PROBLEM: If you set <plugin capture="true"> then you cannot move the panorama at all. If you set <plugin capture="false"> then you can move the panorama but you can also move it even if you click inside any control.
This problem arises from the fact that you have to use an application container which "wraps" your entire plugin. So when you capture="true", krpano thinks that your container is a control, so it ignores the mouse event. If you capture="false" then this allows krpano to handle any and all mouse events include those inside your controls; if you click and move your mouse while inside a button, this will also move your panorama.
SOLUTION: The best solution I've come up with is setting capture="false" and then blocking the mouse event from bubbling down to krpano if mouse down event comes from any control that is not the application container.
Add an event listener for MOUSE_DOWN for you application container:
Then block the event if it comes from any control that is not the application container:
private function onApplicationMouseDown(evt:MouseEvent):void
if(evt.target != this)
evt.stopPropagation();
PROBLEM: You get a blue or white box that covers your panorama.
SOLUTION: Set the application container backgroundAlpha to 0.
PROBLEM: krpano events (REGISTER, UPDATE, RESIZE) are not triggering.
SOLUTION: I have not found a solution for this yet, but I have a couple of ideas. I will update result soon.
I will update if I come up with more.
Have fun using flex applications with krpano
