- New: architectural projection (view.architectural)
- New: dynamic head/camera swinging effect (control.headswing)
- New: basedir parameter to set the base directory for the xml files loaded by loadpano() action
- New: HTML Embedding examples for SWFObject 2.1 and the "without JS" method via embed/object tags
- New: mouse wheel fixes via javascript
- New: textstyle attributes: origin, edge, textalign, xoffset, yoffset, noclip, showtime (textstyle example)
- New: textfield plugin to show simple HTML/CSS formated texts
- New: user defined contextmenus (right click)
- New: new/updated plugin/as3 interface
- New: progress bar/loopings - more settings
- New: onenterfullscreen,onexitfullscreen events
- New: onover/onout events for hotspots
- New: parameters for actions (%0-%9, %0=name of action, %1-%9=placeholder for the parameter)
- New: optional details setting for each multiresolution level (level[].details)
- New: multiresolution level switching threshold (image.multiresthreshold)
- New: data tag
- New: more tweentypes
- New: lensflare[name] access
- New: krpano_as3_interface updated (better plugin interface, special register/resize events)
- New: freezeview() action
- New: call() action to direct call other actions or as3 functions
- New: loadxml() function
- New: ZOOMBLEND transition for loadpano()
- New: "logkey" parameter for the krpano tag to disable the 'O' key
- New: updated editor/options plugins
- New: updated documentation
- New: updated and new examples
- Bugfix: in the loadpano() call the next panos xml "onstart" was overwritten wrong
- Bugfix: when not using KEEPPLUGINS some plugin attributes of the new xml were loaded wrong
- Bugfix: tween/timerset without time setting -> now default 0.5 seconds
- Bugfix: the domainname in the "domain license" was case sensitive
- Bugfix: wait(blend); without a previous pano
- Bugfix: many single action calls from plugins or javascript work now
- Bugfix: lensflares order (now behind plugins)
- Bugfix: lensflare[name].visible
- Bugfix: plugin width/height will be automatic set to original imagesize if not already set
- Bugfix: plugin onhover was also called when plugin.visible was false
- Bugfix: new symmetric tesslation for cubical panos, this fixes the the problem of "appearing lines"
- Changes: tessmode=3 for cube images per default now
- Changes: relative XML-Paths has changed, now it's possible to set the base directory for xml loading, have a look at the "krpano basedir" attribute, per default the path of the first loaded XML file is the base path for all following xml loads. if you have problems with this new version add this parameter to the krpano tag: basedir="%CURRENTXML%"
- Changes: default folder of "krpano_default_flares.jpg" is now the folder of the swf file
- Changes: new radar plugin with changed interface (now "plugin[radar].heading" instead of "radar.header") (but using the old radar plugin is still possible)
