how to protect in blogspot.com with krprotect?
  • I purchased krpano around Feb. I am happy user of krpano with krprotect. Everything is working fine if I put my result in one folder under webfolder and protect it with site address.
    When I protect the pano with my site address and blogspot.com address, the pano cannot show on blogspot.com site. It shows with license error.
    If I do not protect with site address, it can show in blogspot.com site. How can I protect pano in blogspot.com site?
    Thanks in advance for your guidance.
    Wilco
    http://www.brac360.ky
  • . I do not know how it works in the link that you give me.
    It works if I don't restrict with site address in krprotect.
    http://rootfive.blogspot.com/2010/06/west-end-park.html, there is no protection, if i protect site address, it gives me error and cannot view.
    I need to grab the link from different hosting site because I cannot upload swf to blogspot.
    I want to protect swf file so that it can only view in blogspot site. I do not want anyone to download and post again in any site.
  • Interesting challenge here.
    I'm guessing that when you use kprotect to restrict the domain... it is in effect saying that the swf can only be loaded from that domain (i.e. has to be hosted there)
    If you restrict it to the hosting domain... can you still embed it on blogger?
    Update:
    You can protect using domain limiting and put in the hosting domain. You can then embed in blogger.
    If the swf file is moved to a different domain... it will not work.
    Sample - http://panoblogger.blogspot.com/
    Now - if you want to prevent people from embedding - will have to work on that.
  • Not sure if it matters, but I saw a different embed format...
    <embed pluginspage=" http://www.macromedia.com/go/getflashplayer" width="536" height="300" type="application/x-shockwave-flash" src="http://yoursite.com/path/to/your.swf"></embed>
    the pluginspage attribute isn't required - but looks to be good practice...
    http://code.google.com/p/doctype/wiki…nspageAttribute
  • Hi Graydon,
    Thanks for your test.
    I have no issue with quick test - original domain posting in blogspot.com.
    But I have same issue with second test - moved to a new domain like you.
    Here is what I want to achieve if I confuse you since english is not my first language.
    I want to post pano in my blogspot same as the main site. But I want to protect both main site and blogspot so that other's cannot link or download and reuse it without permission.
    In krprotect domain restriction, I add two domain when I generate protected swf file, one is rootfive.blogspot.com link and another is main domain link http://www.brac360.ky. It is ok, if I post the output in main site without license error, but if I post in blogspot.com, I got license error even though I add in the blogspot.com domain in krprotect. How can I post protection in blogspot?
    Thanks,
    Wilco
