Mouse position and more question
    I want ad point (hotspot part) on mouse click.
    mouse.x return only mouse position and write only on trace
    set(hotspot[newspot].ath, mouse.x ); - NOT Work
    Please do you know:
    1. how write mouse position on ATH and ATV (not x, y)?
    2. How insert position tu hotspot?
    3. How debug all value of some object (eg. mouse).... IN PHP var_dump(mouse).... but what there?
    4. Is possible use of plugin "editor" only part of "add polygonal hotspot"?
    5. Where is api documentation? http://www.krpano.com/docu/api ... is removed :(
    Thank's for answer of any question. Thanks, Thanks.... thanks
    I use in action script:
    set(some_var, some_text_information);
    js(show_data( get(some_var) ) );
    Javascript:
    function show_data(value){
    alert(value);
    alert give me "get(some_var)" ... not "some_text_information"
    Where is mistake?
  • Hi brz00ro,
    Quote
    Then it seems that the get() is not resolved inside a js() function...
    So, try in this way:
    xml:
    js(show_data( some_var ) );
    javascript:
    function krpano()
    return document.getElementById("krpanoSWFObject");
    function show_data(arg)
    alert(arg);
    var result = krpano().get(arg);
    alert(result);
    SAlut.
  • Code
    xml:
    set(ddata,get(hotspot[newspot].point[0].ath));
    trace(ddata); -----> this return eg:.... -15.75485457
    js(write_flash(ddata));
    the same result:
    js(write_flash(get(ddata)));
    my question... how get ddata on javascript
    javascript:
    function write_flash(value){
    alert(value); --> return 'ddata' not -15.75485457
    on: js(write_flash(get(ddata))); return 'get(ddata)' not -15.75485457
    I try your solution....
    krpano = document.getElementById("krpanoDIV");
    alert('test');
    alert(krpano.get(ddata));
