Pourquoi utiliser MAMP?
J'utilise mamp en local ce qui me permet d'éviter les erreurs de sécurité de flash comme par exemple pour le plugin gmaps...
Pas de soucis le principal c'est que ça marche chez toi
You're welcome, but if it work now, it's good for you
oki
When I load the pluggin locally using krpano beta8 and a recent download of the plugin (readme starts with 19th of March date) I only get one of my thumbnails. When I load the file I get the message that it "Loaded 1 of 4 thumbnails" but I don't know why it does not load more than one.
fixed, found the naming error when uploading an example.
I have changed the font to Arial in my gallery1.xml document but when I load the file it still uses the wide latin font. Any ideas on this?
You have to change it on the .fla File
Thanks for your help Job.1!
Just in case someone else encounters this problem, I noticed that the variables won't work in the gallery1.xml file. ie <thumb>../thumbs/dv10_thumb.jpg</thumb> will work but <thumb>%FIRSTXML%../thumbs/dv10_thumb.jpg</thumb> will not.
This error message comes in the Firefox 3 with Flashplayer 9. (look on screenshoot)
Only the first Thumb is loaded and the rest not.
With version 10 there comes no error message.
Greets,
Ralf
hello !
i use the plugin, scrolling thumbnail. It works very well with krpano licence, offline and online.
but when i want to use kprotect ,i get this message :
"file not found
/User/gb/Desktop/defilement/as3Thumbsforkrpano.swf?TheXML=./gallery1.xml"
and if i generate a krpano.swf with kprotect, the panorama works well offline, but not online, thumbs have no scrolling
Job1 had the recommendation of changing the font in the .fla file rather than the xml since changing the font in the xml was not working. I am not all that familiar w/ the scripting language in flash, when I search for "font" I find the two following bits of code:
starting on line 198
ZitatAlles anzeigen
var myTextFormat:TextFormat = new TextFormat();
myTextFormat.font = xmlData.thumboptions.font_type;
myTextFormat.size = xmlData.thumboptions.font_size;
info_txt.blendMode = BlendMode.LAYER;
info_txt.textColor = xmlData.thumboptions.font_color;
info_txt.setTextFormat(myTextFormat);
info_txt.alpha = xmlData.thumboptions.font_alpha;
info_txt.text = "LOADED "+p +" OF "+(xmlData.pic.length ())+" THUMBNAILS";
and starting on line 282
ZitatAlles anzeigen
//++++ while we are here, we change the text size, color, options
//++++ don't know if this is the best way to do this, but it works, if anyone has a better idea, polease feel free to share it :)var myTextFormat:TextFormat = new TextFormat();
info_txt.text = String(xmlData.pic.about[targetThumbs]);
I am not clear how to hardcode the font. Would anyone like to enlighten me?
I see one problem - if I position the plugin on top then there is a big area below the plugin, where I can control it.
And this is not very comfortable, becuase normaly you steer the panorama in the middle of the screen, but now the thumbnail-plugin is active there.
and also another problem. for me the alpha of 0.2 of the images is too much transparent, so I set <InitialAlpha>.6</InitialAlpha>
So you can see the thumbs better. But after one rollover the alpha of this image goes back to 0.2 and is almost invisible
I am sorry ,I make a mistake not in the .fla but in the xml
The Problem is solved. It works with REV7
where can I download the latest version?
No problem Job.1, I appreciate you trying to help. The problem is I have changed it in the xml but it still displays the "Wide Latin" my xml is
ZitatAlles anzeigen<images>
<thumboptions>
<ScrollSpeed>25</ScrollSpeed>
<thumbW>140</thumbW>
<ThumbPadding>20</ThumbPadding>
<ShownThumbs>3</ShownThumbs>
<ThumbOffset>0</ThumbOffset>
<thumbH>70</thumbH>
<InitialAlpha>.2</InitialAlpha>
<font_type>Arial</font_type>
<font_size>15</font_size>
<font_alpha>1</font_alpha>
</thumboptions>
but the result can be seen here, http://www.xrez.com/krpano/html/diving.html
The wide latin problem does not seam to be browser related. I looked on vista in IE, FF, Chrome and Safari and all showed up as wide latin on Vista.
Perhaps you don't have the lastest version because is ok at home
Are you on vista x32 or x64 at home?
The 3 vista machines I have tested with are x64. Can anyone else test w/ x32 vs x64? When I look at my page http://www.xrez.com/krpano/html/diving.html or the example page https://krpano.com/plugins/userpl…sforkrpano/#top I see the same wide latin. I looked at my google analytics and about 30% use vista, so I have to find a fix for this.
I grabbed the version from the sticky at the top of this "Scrolling Thumbnails" forum just a few days ago, but there is no version number in the text.
I am on Mac OS
But I had make a recherch and you can change the font in the .fla
Select the text field and see the properties
you have a field where you can change the font
