What I'm trying to do is to create a hotspot that reads a bitmapData from the other plugin and displays it. The communication part is solved already. The problem is when I'm trying to set the distorted attribute to true. The image is being cropped! I can see only the portion of the swf that is defind by: [SWF(width=....)] in hotspot's swf file. When distorted is set to false the hotspot shows whole image (loaded bitmapData from the plugin). I can't set the [SWF(width and height)] values because it's depended on the plugin that sends the bitmapData and on xml file. When i set width and height in xml then my hotspot is being stretched (scaled). I've found the usecontentsize attribute that sounds like a solution for me but when i set usecontentsize to true then hotspot disappears.
So, in other words: I want to create a hotspot with dinamic dimensions that don't crop the conent and is distorted.
How can I achieve it?
Please help. Without this hotspot whole project and months of work will go to trash.
