COMBOBOX selectIditem need help
    I dont understand what is wrong with my script ( action script ) ,
    I try to use the selectIditem ability from the combobox and all i get is a error message :
    unknown action command: plugin[cb_meditor_scenehs].selectiditem
    krpano.call("plugin["+comboboxName+"].selectIditem("+idItem+")");
    I dont know exactly what is wrong... any idea?
    I know for sure that the combobox have a good name because if i try to delete it with :
    krpano.call("removeplugin("+comboboxName+");");
    it delete it perfectly.
    Also im able to change the visibility....
    Einmal editiert, zuletzt von 200b0cvm (20. April 2011 um 23:10)
  • Hi
    Thanks for your answer, i just found the answer...
    I was tring this :
    krpano.get("plugin["+comboboxName+"]").selectIdItem("+ItemID+");
    instead of :
    krpano.call("plugin["+comboboxName+"].selectIdItem("+ItemID+");");
    now it work... :P
