versuche das embedexample mit einer document class in CS5 zu bauen
package
import flash.display.*;
import flash.events.*;
import flash.system.*;
import flash.net.*;
import flash.filters.*;
import flash.geom.*;
import flash.text.*;
import flash.utils.*;
import flash.xml.*;
import flash.ui.Mouse;
import krpano_as3_interface;
public class krpano_embed extends Sprite
public var krpano:krpano_as3_interface = null;
public var krpanoloader:Loader = new Loader();
public function krpano_embed()
krpanoloader.contentLoaderInfo.addEventListener(Event.COMPLETE, krpano_load_complete);
krpanoloader.load(new URLRequest("krpano.swf"));
public function krpano_load_complete(event:Event):void
event.target.content as Object.embeddedstartup(stage, krpano_ready);
public function krpano_ready(krpanointerface:krpano_as3_interface):void
krpano = krpanointerface;
// open the krpano log and show a message:
krpano.call("showlog(true);");
krpano.trace(0,"ready...");
// load a inline xml with a preview image as demo
krpano.call("loadxml('<preview type=\"grid(cube);\" />');");
// load a pano xml:
// krpano.call("loadpano(pano.xml,null,MERGE,BLEND(1));");
// get notified about krpano resizes
krpano.set("events.onresize", krpano_resize_event);
// change the pano area to a fixed size:
var area:Object = krpano.get("area");
area.x = 20;
area.y = 20;
area.width = 400;
area.height = 300;
// examples how to add/change plugins from as3:
// 1. the "set-interface" way:
krpano.call("addplugin(button1);");
krpano.set("plugin[button1].url", "button.jpg");
krpano.set("plugin[button1].parent", "STAGE");
krpano.set("plugin[button1].align", "righttop");
krpano.set("plugin[button1].x", 10);
krpano.set("plugin[button1].y", 10);
krpano.set("plugin[button1].onhover", "showtext(toggle pano layer);");
krpano.set("plugin[button1].onclick", toggle_krpano_visibilty);
// 2. the direct object way (faster)
krpano.call("addplugin(button2);");
var button2:Object = krpano.get("plugin[button2]");
button2.url = "button.jpg";
button2.parent = "STAGE";
button2.align = "righttop";
button2.x = 10;
button2.y = 50;
button2.onhover = "showtext(change area size);";
button2.onclick = toggle_krpano_area;
public function krpano_resize_event():void
krpano.trace(0,"pano resize - pos=" + area.pixelx + "," + area.pixely + " size=" + area.pixelwidth + "x" + area.pixelheight);
public function toggle_krpano_visibilty():void
var imagelayer:Sprite = krpano.get("image.layer");
if (imagelayer.visible == true)
imagelayer.visible = false;
else
imagelayer.visible = true;
}// toggle also the plugin layer
krpano.set("plugin.visible", imagelayer.visible);
public function toggle_krpano_area():void
// just toggle between two sizes
if (area.x == 20)
area.x = 0;
area.y = 0;
area.width = "100%";
area.height = "100%";
else
area.x = 20;
area.y = 20;
area.width = 400;
area.height = 300;
bei compilieren sehie ich dann
E:\Downloads\krpano-1.0.8.12-2010-11-24\examples\as3-interface\flash-cs4-embed-example\krpano_embed.as, Zeile 30 1061: Aufruf für eine möglicherweise nicht definierte Methode embeddedstartup über einen Verweis mit statischem Typ Class.
leider ist mein Flash-latein nicht ausreichend um weiter zu kommen.
Kanns du mir ein Tipp geben?
Greetz
Mil
