activate handcursor ?
I get the same results as you.
handcursor="true"
selectable="false"= no handcursor
If I change selectable="true" then the cursor changes to look like a capital I... I forget what that's called.
Only time I get the actual "hand" is when it goes over links within the text.
I don't have a solution... but wanted to confirm the issue... as it seems that once you set handcursor to true... it should show up.
General reminder also - you may need to clear your cache between changes... I was switching things back and forth and couldn't get anything to change until I remembered to clear the cache.
Graydon
I know about the cache
You may use Web developper for Firefox. You can disabled the cache with this wonderful plug-in. Very useful when programming something on the web !
to get a handcursor over the textfield plugin - the "children" attribute must be set to "false":
with children="false" the sending of mouse events to the sub-objects (childrens) of a plugin is disabled, this is necessary because internally the textfield plugin has a Flash "TextField" subobject which catches the mouse and changes it's cursor,
Thanks nelk... I use the web developer plugin... and probably have skipped over that option several hundred / thousand times and never realized it was there.
