activate handcursor ?
  • I get the same results as you.
    handcursor="true"
    selectable="false"
    = no handcursor
    If I change selectable="true" then the cursor changes to look like a capital I... I forget what that's called.
    Only time I get the actual "hand" is when it goes over links within the text.
    I don't have a solution... but wanted to confirm the issue... as it seems that once you set handcursor to true... it should show up.
    General reminder also - you may need to clear your cache between changes... I was switching things back and forth and couldn't get anything to change until I remembered to clear the cache.
    Graydon
    to get a handcursor over the textfield plugin - the "children" attribute must be set to "false":
    <plugin url="textfield.swf" ... children="false" ... />
    with children="false" the sending of mouse events to the sub-objects (childrens) of a plugin is disabled, this is necessary because internally the textfield plugin has a Flash "TextField" subobject which catches the mouse and changes it's cursor,
