I have a rotating panorama, at a certain point it loads another panorama (some one, just other colors). I want to seamless blend the panorama intoo the other WHILE rotating. At the moment, the panorama stops rotating when I blend the other (the other rotates).
<action name="rotate">
oninterrupt(stopall()); <!-- the user can interrupt the animation -->
delayedcall(15, loadnext()); <!-- starts a timer for 15 seconds, and then loads the next -->
lookto(180, 0, 70, linear(10), false, false); <!-- meanwhile rotate the panorama 180degree, 10degrees per second -->
wait(blend);
<action name="loadnext">
loadpano(image_002.xml,null,MERGE,BLEND());
rotate();
The reason I dont use autorotate is, because I forcifully want to go to the next panorama after 15sec, even if the user interupts it.
Can someone help me? If this doesnt work, Ill have to create a complete solution with 3d distorted hotspots instead of panoramas.
