interactive hotspot with a slider?
  • Hi all,
    can somebody help me how to use the slider from this example http://www.krpano.com/examples/10815…bes/slider.html to blend not the cubes, but the interactive hotspot? I tried to study the code, but it is really too much for me :(
    I would like to have this result but with a slider :https://krpano.com/examples/hotspotextract/
    (it is from the tutorial http://www.krpano.com/forum/wbb/inde…D=7272&pageNo=1)
    many many thanx!
    Igor Socha
    the slide code in that example calls a 'setblend' action with a value from 0.0 to 1.0,
    so you could just:
    1. remove the current setblend actions (for flash and html5)
    2. add a new setblend action where you set the alpha of the hotspot you want to change,
    e.g.
    <action name="setblend">
      set(hotspot[...name...].alpha, %1);
  • can U advice me with one other problem, please?
    I have the room with the RGB lamps - the color of these can be changed with RGB touch pad controller - something like this one:
    I have shot several main colors (dark and light blue, violet, pink, red, orange, yellow, green) of the light and I´d like to use it as hotspots -
    I think, it would be simple to assign specific onclick event to show the hotspot with particular color light to different parts of this controller - which I know how to do easily, but would it be possible to do it with mouse dragging - so it would change the hotspots gradually? For example, if the mouse is positioned between light and dark blue, there would be 50/50 % alpha of dark blue and light blue hotspots - when I will move the mouse to blue, the blue light hotspot willl be 100%, all theothers would be 0%, when I move the mouse towards the violet, gradually the violet hotspot would appear... etc.
    What do you think? would it be too complicated?
    Thank U,
    Igor Socha
