[solved] progress doesn't work after update
  • Hi, I have a small problem and I can't find the issue...
    I have a gigapixel panorama from last year and first build with krpano 1.8.14.
    Today I want to update the files to 1.6.4 so I just replace krpano.swf and swfkrpano.js with the new version, and then everything work except the progress settings :
    <progress showload="bar(top,100%,5px,330px,0px,shaded,0x000000,0xffffff,0xAAAAAA)" showwait="none" showreloads="true"/>
    instead of showing the bar it shows the default loading animation (with bullets), I tried with parent="STAGE" but it doesn't changes anything ?
    Is I switch back to 1.8.14 version it works all right...
    Any clue ?
    sorry I can't show you the pano as it's not online for now
    Einmal editiert, zuletzt von jeromebg (23. Juni 2013 um 21:46) aus folgendem Grund: Ok, found the problem, I had a version="1.0.8.14" in one of the xml files included, looks it was the problem...
