Hello,
I'm wondering if the reason I can't see any image hover hotspots in my phone is because my android phone is not using 4.0.
Other hotspots such as hotspots for navigation are visible. Maybe I'm doing something wrong here.
Hello,
over/hover/out Events aren't supported/possible on touch devices, but hotspots itself should work of course.
Hi! I have the same case. Here is the code:
<layer name="map" url="skin/map.png" keep="true" align="lefttop" x="16" y="16" width="200" height="204" handcursor="false" scalechildren="true" maskchildren="true" >
<layer name="main" type="container" align="lefttop" x="30" y="47" width="63" height="129" maskchildren="true" alpha="0.5" onover="tween(alpha,1,0.5,0.1);" onout="tween(alpha,0.5,1,0.1);"> <layer name="spot_main" url="skin/map_room_main.png" x="100%" y="100%" zorder="2" onclick="loadscene(scene_main, null, MERGE, BLEND(1));" /> </layer> <layer name="small" type="container" align="lefttop" x="104" y="96" width="33" height="36" maskchildren="true" alpha="0.5" onover="tween(alpha,1,0.5,0.1);" onout="tween(alpha,0.5,1,0.1);"> <layer name="spot_small" url="skin/map_room_small.png" x="100%" y="100%" zorder="2" onclick="loadscene(scene_internal_(small), null, MERGE, BLEND(1));" /> </layer> <layer name="tables" type="container" align="lefttop" x="112" y="31" width="47" height="61" maskchildren="true" alpha="0.5" onover="tween(alpha,1,0.5,0.1);" onout="tween(alpha,0.5,1,0.1);"> <layer name="spot_tables" url="skin/map_room_tables.png" x="100%" y="100%" zorder="2" onclick="loadscene(scene_internal_(tables), null, MERGE, BLEND(1));" /> </layer> <layer name="red-walls" type="container" align="lefttop" x="104" y="131" width="56" height="48" maskchildren="true" alpha="0.5" onover="tween(alpha,1,0.5,0.1);" onout="tween(alpha,0.5,1,0.1);"> <layer name="spot_red-walls" url="skin/map_room_red-walls.png" x="100%" y="100%" zorder="2" onclick="loadscene(scene_internal_(red_walls), null, MERGE, BLEND(1));" /> </layer> </layer>
Outer layer is visible in html5 viewer (chrome, windows), and child layers are not. And they are not clickable too. All works perfect in Flash version.
