Is there another function I can use that won't block the thumbnails? I attempted to use the bombtimer but something makes the counter count faster after cycling through the tour once. I went back to lookto and it would work great if the thumbs weren't blocked. I do insert oninterrupt(break); before the lookto movements and it does stop the lookto movement if you click on the main picture ( not over the thumbs ). I am using the default thumbnail build.
thumbnails blocked from click when using lookto
Hi!
Try setting "nonblocking" to "true" inside the lookto() attributes. See here for more details:
http://www.krpano.com/docu/actions/#lookto
When set to true, the "nonblocking" makes the user interface cliclable during te Lookto movement.
Thanks Alexey,
I somehow missed that particular command but I encountered a few issues that way as well. I will try again with a few if statements and see if it works as I want.
I had a setup to do three lookto actions but if a thumb was clicked, it would switch scenes and the lookto actions would still be in progress in the new scene.
Jarred
Tuur somehow managed to workaround this issue. See here:
Here is what I did to stop the lookto. It requires a click anywhere to stop the rotation and then the thumbs are clickable. I stretched a small image over the entire screen. onclick stops the action.
<action name="look">
addlayer(cover);
set(layer[cover].alpha,0);
set(layer[cover].url,sq.jpg);
set(layer[cover].zorder,10);
set(layer[cover].width,100%);
set(layer[cover].height,100%);
set(layer[cover].onclick,stop(););
delayedcall(1,look2(););
</action><action name="look2" >
lookto(359,0,120,linear(20),true,true,look4(););
</action><action name="stop" >
stopall(); wait();
removelayer(cover);
set(events.onidle,look4(););
