It don't want work on Mac
klaus.krpano -
10. Dezember 2008 um 20:53 -
Geschlossen
Hi, what does not work?
did you get any error messages?which Mac OSX version do have you?
I have only OS X 10.4 but there everything works... -
Sorry again Klaus
I am not awake today, all work well and a special thank for Krpano protect -
hi, i'd like to say thank you for new beta version at first :)
and i have one question: is the AS3 Interface for krpano 1.0.7 compatible with 1.0.8? seems to be but.. -
HI Klaus
We made tests and we got something like this.
1.0.8-beta5
1.0.8-beta6
How to repair this
Pietero & Pablo
spacerywirtualne.pl teem -
When doing this sample... http://testsite.marlincreek.com/demo/xmlscroll/ ...
... the plugin oy seemed to be working backwards.
I had to use this...
... with the -5 in order to get the image to move "UP" even though the origin / edge is bottom.
The ox seems to be acting as I would expect it to.
Are these events added in this beta?
ZitatI've planned to add new events in the next version,
e.g.
"onxmlcomplete" - when the xml was loaded, and krpano is ready for new loadpano calls
"onviewcomplete" - when the loading of the current view was done, can be used for multiresolution panoramas,
"onloadcomplete" - when loading of the whole panorama was complete (for normal panoramas)Regards,
Zephyr -
and i have one question: is the AS3 Interface for krpano 1.0.7 compatible with 1.0.8? seems to be but..Hi,
yes, the AS3 interface is upward compatible
HI Klaus
How to repair this
Pietero & Pablo
spacerywirtualne.pl teemHi,
thanks for finding this bug!
this was a side-effect of the new ox/oy/rotate parameters and the changed position calculation
here is a fixed version: krpano_swf.zipI'll do some additional tests and then integrate it in the normal download package.
EDIT: the bugfix is now integrated in the normal beta download package!
the ox/oy parameters are not related to the origin/align parameter like the x/y parameters,
they work always the same: -x = left, +x =right, -y = up, +y = downnote - the ox/oy can be also used for hotspots,
and together with rotate and % values for x/y or ox/oy same interesting effects are possiblebtw - great work with the xml driven thumbnails
Regards,
ZephyrHi,
in this beta - "onpreviewcomplete" and "onloadcomplete" are implemented
(onxmlcomplete would be near the same like onstart, but will be added soon anyway)e.g. - for testing:
Code<events onpreviewcomplete="trace(onpreviewcomplete);" onloadcomplete="trace(onloadcomplete);" />
the next beta version is ready - 1.0.8 beta 6
- <plugin>/<hotspot> - ox/oy - addtional x/y offset, % values can be used and they are relative to the own size
- <plugin>/<hotspot> - rotate - rotation in degrees
- <plugin></hotspot> - enabled - enable/disable all plugins or hotspots globally - "hotspot.enabled", "plugin.enabled"Hi, Klaus !
I was hopping that 1,0,8 beta 6 would be ok to fix this problem (Use a plugin as a hotspot...), but it doesn't seems...
My map can't still be placed with spherical coordinates when I name it
"plugin" instead of "hotspot", and my mappoints are still not turning
with my map... or is it because I don't know the way to use it ?Regards,
David
Hi all,
I've updated the beta 6 version: (please download again)
- the align bug was fixed
- and in the kmakemultires tool a bug regarding partial panoramas was fixedbest regards,
with my map... or is it because I don't know the way to use it ?Hi, that's possible now
declare the map and the spots as <hotspot> with the same ath/atv values,
and align the spots via the ox/oy parameters,this is not the best way (a child<=>parent system for plugins and hotspots is in work),
but it's possible nowbest regards,
Ok, I'll try !
Thanks ;) ! -
Ok, I tried... :(
Code<hotspot name="spotx" url="../../images/mappoint_bleu.png" keep="true" zorder="4" origin="bottom" ath="0" atv="90" x="200" y="200" scale="0.55" zoom="true" alpha="1" handcursor="true" width="12" height="12" onhover="showtext(Eiffel);" onclick="action();" />
I thought it was like this... but I must be wrong...
Sorry -
origin, x, y are not attributes of hotspots for placement... only the ath, atv are... and now the ox, oy for offsets.
With the offset x/y, I don't know if you can specify an edge (relative to the plugin image)... or if the offsets are always taken from a center point.
yes, ox/oy must be used instead of x/y,
at the moment they are only relative to the hotspot center -
Ok, that's it ! Great !
I have 3 files in the same folder - kprotect.exe,krpano.swf and krpano.licence ( my unlimited domain) and It is not possiblle to generate protected file.
Warning message:WARNING - licenses not found - DEMO MODE!
My license is recognised by kprotect.exe under "krpano Domain or Unlimited Domain License - "krpano.license" - third row.
What am I doing wrong? Do I need some other file with license?
Marty -
