Math formula / function of drag2d?
  • Hi everybody,
    Are there somewhere the formulas for touch/mouse movement of krpano (the ones used in control) or could somebody provide something similar? Looking especially for drag2d.
    What happens here that I have a pano on one side of the screen while other elements on the other side of the screen - which have nothing to do with the pano (the panorama 'scene' doesn't reach, overlaps it nor underlays it) . However, the user should be able to touch there and control the pano like it would be one huge pano element. I don't see any other way of achieving this but putting an overlay layer, check the touches on this layer and then control the krpano according to the touchpoints. But for this I would need some movement function, of course. Any ideas / help appreciated!
    Thanks a lot!
  • I think this is what you're looking for:
    Sorry for the weird formating. I can never get it right when I paste some code here *smile*
    That's the bare minimum code for the behaviour, which should be self explanatory. Then you need to add more attributes to create the buttons.
    Cheers,
