vertical flat pano [Solved with 1.19 pr14]
Hi Umalo,
Did you try limitview="fullrange" ?
https://krpano.com/docu/xml/#view.limitviewEDIT:
This seems to be a bug!!
KlausHope it helps,
Yes, there is a bug with flat-pano rendering since 1.19-pr12.I have unfortunately also noticed it only first a few days ago.
But it's already fixed for the next release.Best regards,
Many thanks for confirmation.
Hi all,
I have the same problem with this image with version 1.19-pr13.
Marco
Quote
Yes, it's a bug - please see above - it will be fixed in 1.19-pr14.
As workaround it would be possible to remove the <preview> element.
Hi Klaus, do you have a date in mind ?
Quote
I don't know, that part is already fixed, but several other things are still in work.
If you want you can contact me for test version in the meantime. -
Thanks Klaus for this fix
Hi Klaus
Any workaround available related to bouncinglimits on Flat vertical pano?
Are control.mousetype & touchtype compatible with mouse & touch as I see in documentation only: mouse & touch while flatpano_setup.xml still use: mousetype & touchtype (maybe there is some catch why bouncinglimit it not working)?Update where vertical flat pano is displayed correctly but bouncing limits have some offset: Link
Test package: Download -
Sorry, but not sure what you mean... they were working as they should so far I see...
Maybe the flatpano_setup.xml behavior is confusing - it is using limitview=lookat instead of limitview=auto or limitview=range.
QuoteAre control.mousetype & touchtype compatible with mouse & touch as I see in documentation only: mouse & touch while
That 's basically the same, 'mousetype' and 'touchtype' are the old variable names, 'mouse' and 'touch' the new variables names. But internally they are both mapped to the same.
Thanks.
