Hello! I am having some issues, maybe it is something wrong I am doing...
Some faces of my object of the dollhouse are inverted, and it seems it inst rendering properly, just only one panorama is being used in the baking process.
Any idea on how to fix it?
Wrong faces orientation and panoramas SOLVED!
ThanksI Just started another tour with the same panoramas. I did one reference in one tour and than, one subreference on the another, so I can navigate between then. When I start to create the geometries to test, some faces are inverted and not using the proper panorama. In this version there is no more that preview tool...
What am I doing wrong?
Really this is becomng realy frustrating. I have polygons were are not being rendered... And the faces are inverted...
Nobody had this problem before?
most likely geometry problems due to modeling mistakes...
maybe share your model as stl or obj -
I am modeling inside everpano, with the polygon tool
Is there any recomendations to modeling on everpano? Like start the polygon from the right or left? But I have tryied both ways...
i checked and yes,some polygons are flipped
sadly i dont work with everpano, so i can't tell you how to deal with this -
You should split your apartment into multiple pieces and use the model editor to locate them
You can take a look at the documentation part here :
https://everpano.com/building_model.php
Kind regards
Thank you, I was creating an entire geometry... that solved
