dear forum
we from the "stadtarchaeologi hall" want to expand a panorama tour as an audio guided tour.
the best solution would be, to do this using play sound at hotspot...
in practice the following problem arises. whenever you drive over a hotspot, the audio track starts over again.
if users listen to the entire text, you can still use the oncomplete function, but very often the entire audio file is not played.
does anyone have an idea how to integrate some kind of pause function.
of course it is possible to use audio hotspots that you can start with oncklick and also set them to pause. but that would be an inelegant compromise.
thanks for help klaus
