When I'm in fullscren mode and I load a new panorama, the controller come as if I was in the normal mode and I cannot use the button to go back to the normal mode...
What can I do to resolve this problem?
Fullscren mode and controller:
What command are you using to change to fullscreen? Do you have new instructions in each pano regarding fullscreen? If so, they are overwriting the previous settings and setting the command to open as fullscreen even though it is already there. Perhaps try using something like
onclick="switch(fullscreen)";
I used to have all my pano XML files contain all/most instructions but now I have all my standard plugins and settings only in my first pano XML only. This only works if you want them in every pano, of course.
Hi Jarredja,
I'm doing like you and now, how can I do to get the command fullscreen opened when I load a new panorama in the fullscreen mode?
You can se the code here ...Best regards,
Laurent
Try adding keep="true"
It doesn't work
How do you do yourself to keep the command "exit FS" when you load a new panorama? -
there is standard limit in fullscreen... it is restricted by ADOBE itself.. klaus cant do anything with this...
I think you didn't understood what's about...
I open my first panorama and I put it in fullscreen vue. Now, if I open the Google map and load a new panorama, this one will be opened in full screen but with the commands of the normal screen and so, it is impossible to go back in normal screen vue exept with "Escape"...
Do you have a link for us to view?
Here is the link
I see you have it protected. Did you create a new .swf after you added the keep="true" to the plugins and also after you removed the duplicate code? I would say try to get everything working before protecting it all in the end.
Nothing is protected!
Edit: Nevermind
I looked at your xml and it seems the plugins are still listed in each panorama xml file. Did you remove the plugins from each file except for the first initial file? Maybe the server did not replace the old files with the new files?
Hi Jarredja,
Thanks a lot, you are the King!!!
Laurent
Zitat
you are the King!!!
Not a king, maybe just the court jester.
There is so much for me to learn. I like helping others when I am able.
Glad you got it working.
