I have tried to minimize the map 5 seconds after it has started, without success.
I have tried using:
delayedcall(5, action(closemap);
The start of my XML file looks like:
<krpano version="1.0.8 "logkey="false" onstart="action(start);" >
<!--************** KrPano plugins and datas ***************************************************-->
<!-- text styles for startup info -->
<textstyle name="infostyle" origin="top" edge="top" yoffset="10" textalign="center" background="false" border="false" fontsize="40" textcolor="0xFFFFFF" bold="false" effect="glow(0xFFFFFF,0.7,4,2);glow(0x000000,1,4,2);dropshadow(3,45,0x000000,2,0.6);" showtime="1.0" fadetime="1.0" />
<!--************** Open the first pano ********************************************************-->
<!-- start - load first scene -->
<action name="start">
loadscene(scene1, null, MERGE);
<plugin name="introimage" keep="true"
url="introimage.png"
align="center"
zorder="1"
onloaded="set(alpha,0); tween(alpha,1.0);"
onclick="hideintroimage();"
<action name="hideintroimage">
if(plugin[introimage].enabled,
set(plugin[introimage].enabled,false);
closemap();
tween(plugin[introimage].alpha, 0.0, 0.5, default, removeplugin(introimage));
<contextmenu>
<item name="site_link"
caption="Created by http://www.dpinparis.com ...."
onclick="openurl(http://www.dpinparis.com/)" />
</contextmenu>
The closemap action looks like;
<!-- actions -->
<action name="closemap">
set(onclick,action(openmap););
tween(width,45,distance(300,0.5),easeoutquad);
tween(height,45,distance(300,0.5),easeoutquad);
Any ideas?
ALso, if I click on a hotspot t open a new pano, the text appears for x number of seconds that I choose. If I click on the map tp open the pano, the text just flashes. I find this strange as I thought that I load the scenes in the same way:
hotspot load scene:
onclick="loadscene(scene4, null, MERGE, BLEND(1));"
map load scene:
start scen action
<action name="startscene">
showtext(La Cave Bar Mosaique, infostyle);
action(activatespot,scene4, 20);
Any ideas?
Thanks in advance.
