Hallo, i've created here an self rotating and changing tour. the problem is that if i try to use user interaction to stop the actions , it doesn't interrupt the actions
<plugin name="360spiner_data"
currentpano="0"
spin_turn_on="1"
keep="true"
</plugin>
<action name="loadpanos">
set(spiner,0);
trace(spiner);
oninterrupt(break);
if(plugin[360spiner_data].currentpano == 1, check_view();tween(););
if(plugin[360spiner_data].currentpano == 2,load(2.xml, null, MERGE, ZOOMBLEND(1.5,10));check_view();tween();
if(plugin[360spiner_data].currentpano == 3,load(3.xml, null, MERGE, ZOOMBLEND(1.5,10));check_view();tween(;);
if(plugin[360spiner_data].currentpano == 4,load(4.xml, null, MERGE, ZOOMBLEND(1.5,10));check_view();tween(;);
if(plugin[360spiner_data].currentpano == 5,load(5.xml, null, MERGE, ZOOMBLEND(1.5,10));check_view();tween(););
if(plugin[360spiner_data].currentpano == 6,load(6.xml, null, MERGE, ZOOMBLEND(1.5,10));check_view();tween(););
if(plugin[360spiner_data].currentpano == 7,load(7.xml, null, MERGE, ZOOMBLEND(1.5,10));check_view();tween(););
if(plugin[360spiner_data].currentpano == 8,load(8.xml, null, MERGE, ZOOMBLEND(1.5,10));check_view();tween(;);
<action name="check_view">
this action creates 360 spin
