GoogleMaps whole library API features plus Krpano features
  • Hi there.
    It is kinda apart from krpano googlemaps plugin but at MooTools forums you may find a script I did for an easy to use javascript library for googlemaps with MooTools, called MooGooMaps
    And along with my other library, MooKrpano , you will be able to has the best from both worlds.
    See a simple example of both codes working together at:
    http://www.paraisoartesano.com/virtualview
    Note: Old IE versions won't display it well.
    What's better is that I always try these scripts being easy to use and opened for suggestions.
    The MooGooMaps script also has custom widgets (mini applications) I've done like DistanceMeter, What's Around Me and Find Me widgets.
    The Distance Meter Widget is for measuring distances...
    The What's Around Me widget is for displaying only markers around YOU
    and the Find Me Widget use HTML5 Gelolocalization API for finding your position on the map.
    By other side the MooKrpano will let you create panos on the fly using javascript, and also interfacing with your web site DOM elements, like buttons, menus, and else.
    Hope these will be usefull for you and that you may appreciate my effort for document and share them.
