Hi all,
Im curious if you can give me tip how to change map scale when clicking on point on this map.
For example I have this map:
<plugin name="map"
url="pudorys.png"
blendmode="normal"
width="580"
height="462"
alpha="1.0"
scale="0.1"
destscale="1.0"
scalechildren="true"
onhover="showtext(way out, mapfont)"
align="leftbottom"
x="15"
y="15"
onclick="switch(destscale,1.0,0.1);tween(scale,$destscale);"
keep="true"
and then the point on this map:
<plugin name="mbyt01"
url="mappointactive.png"
keep="true"
parent="map"
align="leftbottom"
edge="center"
x="260"
y="90"
zorder="2"
onhover="showtext(Buly,mapfont);"
onclick="loadscene(buly, null, MERGE, BLEND(1));" />
And Id like the map to do "switch(destscale,1.0,0.1);tween(scale,$destscale);" when I click on the point (but I dont know how to set it). Usualy when its set like this, the map stays in bigger scale even after clicking on the active point and I have to clict the map separately to make it smaller when new scene opens.
Is there an easy way that can be added to plugin name="mbyt01" to onclick, or do I have to set something onstart for next scene?
I have map that covers almost whole tour window and I also use the little planet efect when scene start. So when I enter another scene from map, the map actualy covers whole window when new scene is starting and ppl miss the effect..
Thanks for any tips ![]()
