Hi guys
I have embeded video in my VT using videoplayer plugin but it does not display, despite it looks everything is ok.
what could be the problem?
I attached my xml file.
need help ![]()
thankius ![]()
Hi guys
need help ![]()
thankius ![]()
XML by itself isn't helpful. You have to post a link to your tour.
this is the tour:
http://www.aquies.cr/trainforest/tour.html
The video is supposed to be set in the leftbottom.
When I remove the onstart="startup();" action in the krpano root the video does display but not the scenes.
either put the videoplayer inside the <scene> where you want to show it,
or add keep="true" to the <plugin> element of the videoplayer,
note - elements without keep=true will be removed when loading a new pano or scene, and the first action in the xml is the loading of the first scene (see the "onstart" and the "startup" action),
jaja as simple as that???
thank you Klaus now it works fine!
